A.Schrader
- Jul 23, 2010
- 6
A while back I re-built the carb., replace fuel line and filter because the engine stalled out on throttle up (E Gas Problem rotting the fuel line). The original gas tank was a VRO and was replaced w/ a standard 6 Gal. The engine has 100:1 for the ratio. It was suggested that since I was using a different gas tank to now mix @ 50:1. End result, the engine runs slower and the spark plugs have oil deposits. I was thinking about going a little leaner, maybe 75:1 or do you think I should go to 100:1 as indicated on the engine? Also I am not sure what the black knob by the recoil starter is for but when I played with it to go what I am thinking is leaner the engine starts to stalls
