i just bought this motor and it starts up and runs great. i noticed that the bottom exhaust had some water coming out of it like it should but the top exhaust just had exhaust no water what so ever was coming through it and of course the motor got hot quick. i took the lower unit of thinking it was the impeller and it looks like new. i made sure the key was in correctly so i know the impellar is spinning. the housing does not appear to be worn anywhere. the tube is connected properly. so saying all that what else could it be and if the tube is clogged how would you go about unclogging it.
