Mikethesoundguy
- Jun 23, 2010
- 11
I have a 1993 Evinrude 150 V6 Fast Strike on a stratos F/S it started to knock yesterday and got home ran on muffs it got hot but no knock. Impeller and water pump seems to be working, water flows through hole on back fine and cool till it gets hot and steams I turned it off it dosnt shut off i hear no buzzers or warnings. Is there any way to tell if the Oil injection is working. Carbs are clean and ran good since I bought it a couple of months ago. when in idle it ran fine till it got hot and started to puff a little so i shut it off. I have 25 Gallons of gas in it right now. Should i mix some oil in and see if that fixes it? If so do i have to disconnect the oiler or can I just leave it mix if not what's the best or easiest way to disconnect. I would like to take it out monday and am looking for a quick test and fix.
