I have 2001 5hp 4-stroke Evinrude
It has an accelerator pump which appears to be driven by the water flow through the tell tale. This pump is located at the bottom of the carburetor housing. A tube runs to it from the intake housing, and another tube runs out of it to the tell tale.
Can you tell me what the purpose of this is? It seems to be plugged with salty deposits and no water is getting through. I haven't wanted to run this motor until the tell tale is working. So I don't know what effect it is having on operation.
thanks!
thanks!
