will the rigging from a 1995 90hp Johnson Fit a 86 evinrude 90hp?
ChuckNJ
Hi I recently purchased a 95 Proline with a 95 Johnson 90hp. We tested the boat before purchase on the lake and all seemed well. I guess we put 10 minutes running on it. Two days later after fixing some electrical issures with pumps I decided to take back out on lake for shakedown. I am not new to boats as i have a 92 basscat with 150hp Yammy that i rebuilt and hopped up myself with the help of Hydrotec so i feel i knew what to look and listen for but iguess i dont know as much as i think . On this wednesday my son and i took the boat out and were running down the lake full throttle when it just shut down like it was starving for fuel. It took a while to restart but it did not seem right. To make a long story short after running the boat for 10 minutes i pulled the plugs only to fiind one of the plug electrode hit by piston and now it has a hole in it as there is no compression in that cylinder. I called the guy who i bought it from and he wont do anything for me. So my choices are rebuilt powerhead or used motor.
While searching craigslist I came acccross a 86 evinrude the model is e90tlcdg what i need to know is I have not really messed with rigging of a boat just engine. I am a ASE master auto tech but boats are not my specialty. Will the rigging from the 95 johnson work with the 86 evinrude? Any thoughts or suggestions?
Thanks
Chuck
whalerfreak22
Re: will the rigging from a 1995 90hp Johnson Fit a 86 evinrude 90hp?
yes if your rigging has the red plug on the wire harness it will be a perfect match.
