Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Primer Solenoid Lever Position - '90 Johnson 200
  • Primer Solenoid Lever Position - '90 Johnson 200
    Hopefully this is an easy one. I bought a '90 Johnson 200 last year for a boat I'm rebuilding and am FINALLY ready for some test runs . I have the factory service manual and it's not mentioned in there - is the lever on the primer solenoid supposed to be down to run or horizontal to run?
    Checkmate Rebuild: http://forums.iboats.com/forum/boat-...eckmate-eluder
    “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
    ― Isaac Asimov
    Re: Primer Solenoid Lever Position - '90 Johnson 200
    Normal run position is with the handle aligned with the cylindical base of the solenoid.
