Hi
Iam currently installing a crank shaft on 1979 55hp evinrude block.
The manual shows a o ring underneath the top bearing. However the oring that the manual calls for seems to be to big to on the crank in that area under the top bearing.
My thoughts were that this O ring on the crank shaft is an after thought or belongs to another model?
Is there any orings at all on the crankshaft?
Thanks
Colin
Thanks
Colin
