Hi.
Long time lurker, first time poster. I have a question. My friend has a 1968 evinrude sportwin. If i remove the 6 screws holding on the lower gearcase, can i jst drop the case without having linkages, bearings, and shafts to worry about? The reason i ask is that the screw on the port side, farthest from the prop is snapped off. if i can remove the housing, i can grab the screw? We started to try an extractor, but my friend (no kidding) punched and drilled off center. any help is appreciated. Thanks in advance.
