Hello All, I'm having trouble adjusting the carb - I adjust the Slow Speed needle valve as directed in the Top Secret Files and the motor runs fine. My problem is at mid to full throttle - the motor really starts to buck/misfire bad - I turn the Slow Speed needle valve out and the bucking almost stops. Am I missing an adjustment?
The coils, points, plug wires, plugs and condensers are new. Points are set at .020
The carb has a new idle needle and jet.
Any suggestions will be greatly appreciated
