twocyclemania
- Aug 10, 2010
- 505
H! I have a 62 Evinrude 18 with a weird cooling system problem. The motor runs great but the pumping is intermittent. I've replaced the impeller and I've tried two different (used) pump housings; both of which seem to be in decent shape. The tube from the pump to the motor does not leak. I attached a hose to the pipe(at the connection to the pump) and the flow does not seem to be obstructed. The power head has zero corrosion. It was from Minnesota and I've only used it twice in brackish water. I removed the thermostat. What happens is I get intermittent cooling flow and than it will decrease to an inadequate amount. Some times it will pick up again and than fail within 5 or 10 seconds. I've worked on many motors but I've never experienced a problem like this. The speed of the motor does not seem to have any rhyme or reason to this intermittent flow. Eventually the flow will slow down and the head will become overheated.
