My junkyard 1991 Evinrude 8hp starts easy and runs smooth, but puts out huge amounts of black smoke and only delivers half power.
It appears to be running on one cylinder, runs the same with the top spark plug disconnected, but not at all with the bottom spark plug disconnected.
The compression is 110 lb in both cylinders, but I haven't tried a leak down test.
The spark itself looks normal. Both new spark plugs are coated with black oil, but appear to be working fine.
I'm running 50:1 TCW-3 oil with Sta-bil.
So far, I've replaced both spark plugs, rebuilt the carb, replaced the reed plate, run a can of Val-tech De-carb through it, and put about 10 lake hours on it.
Any hope, or am I screwed? "Never buy a junkyard engine, unless you are a better mechanic than the guy that scrapped it!"
