Evinrude model # E35ELCIG (81' 35 hp 2 stroke)
Poured oil into the gas tank and forgot to mix it around and the engine has stalled and won't start (was topping off tank, there was premix already in there). I am getting small amounts of oil on the plugs but no gas. (brand new plugs)
Dealer didn't have the repair manual in stock so I'm hoping to get info from the forum. I'm a bit intimidated by this engine (it's no weedeater engine, looks like carb is down by the crank and under the flywheel). Could use some helpful advice for pulling and cleaning the carbs. I know I'm getting good fuel to the fuel block, and the primer bulb is holding pressure.
Engine will fire right up if I pour a little premix into the cylinders. I tried this 6 times hoping I could burn off some of the oil but can't get the engine to stay running.
Any advice is appreciated. Thanks forum!
