I recently refurbished a 66 'Rude Yachtwin Folding Leg that I picked up for 100.00. Did the carb kit, flushed the tank (was really fouled with varnish), and now have two little problems.
1. Leaking from the fuel petcok/fuel filter: Apparently a slow leak from the threads where the petcock/filter enters the tank. Any gasket or sealant I should use to stop this? I was thinking a bit of Lock-Tite (not on the threads but the joint)
2. Hard starting. This has a fixed high speed needle, I've sprayed everything clean, pretty confident on this, and rebuilt with new gaskets, float, needle seat. I reused the old needle with the neoprene as it seems to keep the bowl from leaking better than the new needle. The float has been adjusted parallel to the bowl top (maybe a little true to it even).
Now to start it; this works the best: Turn the slow needle out 1 turn, three slow pulls on full choke to prime, and then around 6-8 hard pulls full or half choke will start it sometimes. I'm thinking it's vacuuming air somewhere a bit? The father in law remounted the carb to the motor and told me last night he'd used two?? gaskets from the kit? This dosen't sound right and I might have a look tonight and take one out.
New to outboards so any help is appreciated.
4Runner
4Runner
