I just recently bought a few older OMC outboards and also ended up with this 1989 Evinrude 4hp that's in cherry condition. This is the deluxe model with the full gearcase. It's got very low hours on it and the carburetor and fuel pump even have the original gaskets, never gone through. No corrosion at all, etc. I got it running in the tank and it runs smooth as could be. The only problem I found was that it didn't seem to pump much water. So I went down to the local OMC dealer and bought the water pump repair kit and replaced the impeller. The original impeller was a 3 blade but was in good condition, so I replaced with the new impeller anyways while I had it apart. Lower unit was excellent, no corrosion. After replacing the impeller and gaskets, etc, it still wasn't pumping much water. It is spitting out water out of the row of exhaust holes, and at idle it trickles out of the upper water outlet. Running in the tank for about 10 minutes the powerhead warms up, but it's not too hot to touch. I had a later 6hp Evinrude at one time that seemed to pump more water, but as far as I can tell this seems to be normal. I just want to make sure before I put her on the boat and burn it up. Does anyone have any experience with this particular model and how much water it should be pumping through it?
