Ok so I think I am figuring out my surging problem. When it Surges it surges to more power. Meaning it picks up power when it surges. I have Ohmed the coils, changed plugs, decarboned the motor with the sea foam and a gallon of gas trick. Compression on the engine is 95-100 PSI on all 6 cylinders. It doesn't feel like it's missing at all. I am not getting the RPM out of this motor. I run less then 5K full throttle.
Now a different thing I noticed . Exactly like when the surging happens.yesterday, when I push the choke on the key, It revs up and starts performing for a bit.
this is on the IO to OB conversion boat, I ran a 140 on there with no issues, this 175 acts like it is either dropping a cylinder and picking it back up, or is running out of fuel.
Also when I punch it to take off out of the hole, it revs to beat hell for a second or so, then bogs down and starts taking off slower. Like the bowls of the carbs empty down and then runs out of fuel.
Any ideas?
Any ideas?
