No down tilt/trim action! Trim rams will not go in either. I feel like it's not an electrical issue since I've gone directly to the blk, grn, and blu wires feeding the trim/tilt motor. Motor runs fine in both directions. Tilts up, but not down. I've tried to push on the tail of the motor to assist while in the down mode...this does not help. I lubricated the steering tube pivot area. The motor seems free to pivot on that axis. I pulled the manual release screw all the way out and used the punch method from another member to try and release pressure. That didn't seem to help (if I did it correctly!). The manual calls for removing the top of one of the trim cylinders with a spanner wrench to release potential pressure. Does this make sense? Again, the motor runs it fine all the way up but will not run it down. The Motor runs, but no movement whatsoever. I know the motor has been stored for 5+ years. Thanks for your replies!
