gonzalez1975
- Jul 21, 2010
- 8
I have to spray fuel in the carb to start my 85 johnson. Afterwards it will restart fine as long as the engine is warm. How do I get it to start without spraying fuel in the carb?
When is the last time you did a carb rebuild?
The choking mechanism is a solenoid. I have to push the key in to choke.
Guys, thanks for the advice. The choke is working. It does however open by itself after a few seconds while I turn the key. Is it suppose to do that?
I would like to know more about the carbs passages that can't be seen. Where are they?
After taking the boat out today for the first time as its owner (it was my brother's) I notice that it never wants to start unless I spray fuel in the carb.
The choke opening by itself indicates that the automatic choke is still connected. Most of them were disconnected by service departments many years ago. I would recommend that you do the same.
Click the thumbnail twice for the service bulletin and instructions that will enable you to maintain complete control of the chokes.
