Re: Pulse Hose on 86 Evinrude 50 hp,What to do with it?
you need the pulse to operate,you either need a intake that has the mounting bolts with the pulse port in between ,whereby the pump would be held to the pulse port via the mounting bolts,or you need a pump with 3 connection ports,to enable you to use the pulse hose you speak about,my guess is ,you have the wrong replacement pump if it doesnt accept the pulse hose.After thinking about it a bit,R U sure you have an 86 50 hp?because I thought VRO was later on that engine.they had a special tank that mixed fue/oil as well.So,perhaps your eng.is a later yr.look on the intake for 2 tappeed screw holes with a plug in between,that is where your replacement would fit,you need a gasket too.That said,its also possible your engine has a newer intake that doesnt have the tapped holes,hopefully you will find them,otherwise you need the other pump with the pulse port for the hose to connect to
