I'm putting together a basket case of what I think is a 87 48 hp Evinrude. I have no manual and Im to the point I have questions and no answers. I have the original powerhead that is blown and another that I replaced it with. My guess is the one I have is an older model because it had the older fuel pump that did not mount on the crankcase but on the carb cowling.
My problems are:
1.- I have a electric push switch to choke plunger/spring but nothing to hook it to (butterflys or primer) and no reference and it obviously needs some fuel and wont start without a prime. Once it is primed it seem to run fine. There is a barbed nipple on both carb intakes as if it might be for fuel primer into the intake directly
2- The switch does not work in the off position to shut the motor off. The switch has multi wires/functions and I dont have a swith diagram to go by.I dont know the switches functions to test it properly.
3. There is a little black push switch on the controller and I have not a clue what it does but one side wired to ground.
4. There was a safty switch that was mounted on the block that the throttle linkage acitivated and did not let the ground make to activate the starter sol. It was broken and I wired around it because I didnt have a replacement.
I was wondering being I dont have a manual if anyone had and electrical diagram for this that could help me out?
My problems are:
