2004 Evinrude E-Tec 75 hp with less than 100 hours. Cranks, idles, and runs great until appx 4500-4800 rpm when the motor immediately drops back to idle speed. Throttle then no longer works.
If I bring the throttle lever back to idle (neutral), motor will then respond and increase up to 4500-4800. Otherwise runs smooth.
The dealer in my area says I have to bring the boat in and leave it for a minimum of four weeks, maybe longer.
Need help.
art
Need help.
art
