Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Johnson seahorse 6hp (164cc) oil ratio plz.
  • Johnson seahorse 6hp (164cc) oil ratio plz.
    I recently bought this outboard engine but i dont know what oil to use and ratio.Could you plz help me?
    Thanks in advance.
    John , Greece.
    Re: Johnson seahorse 6hp (164cc) oil ratio plz.
    post the model number or year please. It's most likely 50:1, but you want to be sure....
    Please no PMs. My mailbox is full anyway......
    • #3
      Thanks a lot for the reply.
      Where i can find the model number ? The only i know is the serial number.
      john.
      • #4
        Post the serial number. Older models had a two part serial number, the first part being the relevant model number The numbers should be on a plate on the transom bracket
        Do you know the age.
        Generally anything from 1964 onwards will run on 50:1. I think all 6 hp models are after that year. ( except for a couple from the 1920s)
        • #5
          Thanks for the reply @Vic.S.
          The s/n: 6203B17031 I dont know about the age.
          Is there a spesific kind of oil?
          • #6
            6203 is the model number. It makes it a 1972 model
            50:1 fuel mix then using a TCW3 2 stroke outboard engine oil
            That's near enough 1 pint in 6 gallons
            more precisely
            2.56 fluid ounces per US Gallon
            3.2 fluid ounces per UK (Imperial ) Gallon
            20mls per litre anywhere in the world except the USA
            2% if you are a mathematician
            • #7
              more precisely
              Thanks a lot .Thanks for the explanations .And have a nice summer.
