Johnson seahorse 6hp (164cc) oil ratio plz.
feynman
I recently bought this outboard engine but i dont know what oil to use and ratio.Could you plz help me?
Thanks in advance.
John , Greece.
tx1961whaler
Re: Johnson seahorse 6hp (164cc) oil ratio plz.
post the model number or year please. It's most likely 50:1, but you want to be sure....
feynman
Thanks a lot for the reply.
Where i can find the model number ? The only i know is the serial number.
john.
Vic.S
Post the serial number. Older models had a two part serial number, the first part being the relevant model number The numbers should be on a plate on the transom bracket
Do you know the age.
Generally anything from 1964 onwards will run on 50:1. I think all 6 hp models are after that year. ( except for a couple from the 1920s)
feynman
Thanks for the reply @Vic.S.
The s/n: 6203B17031 I dont know about the age.
Is there a spesific kind of oil?
Vic.S
6203 is the model number. It makes it a 1972 model
50:1 fuel mix then using a TCW3 2 stroke outboard engine oil
That's near enough 1 pint in 6 gallons
more precisely
2.56 fluid ounces per US Gallon
3.2 fluid ounces per UK (Imperial ) Gallon
20mls per litre anywhere in the world except the USA
2% if you are a mathematician
feynman
more precisely
Thanks a lot .Thanks for the explanations .And have a nice summer.
