I dropped my lower unit (first time messing with it) and i removed all the shifting levers on the motor. I changed the water impellar, installed the lower unit back, installed all the levers and cables. but now it wont shift back into neutral. I tried to adjust it already but i cant seem to get it to shift back and forth. It will go into forward but wont go back into neutral. The shift cable will not push it all the way to where its suppose to be. I move it manually back and its fine. Helpp!! Thanks in advance
