I have been playing around with this engine for a while now
when i first got it i tried to start it well the floats where messed up so i decided to rebuild the carbs
1.it did run for a few seconds before the rebuild it back fired out the exhaust
then flooded
2.I then checked for spark good on all cylinders
3. checked compression good and even on all cylinders about 125psi
4. rebuilt carbs
5.replaced fuel pump just in case
6.tried to start
7.seems like no gas is getting to plugs they are bone dry
8.now gas is starting to spit out the front of the carbs
all most like the is no crankcase vacum
any help with this would be great
thanks Bob
then flooded
4. rebuilt carbs
6.tried to start
thanks Bob
