Recently got a Johnson 9.9 outboard, I think it's late 70's to mid 80's, it's all white and has the idle know on the port side and carb tuning knob by the choke.
Anyone know the stock carb settings, if I pull the plastic knob off and turn the screw all the way in, how many turns out is the factory setting. Also is there a low speed needle on the carb too? It runs pretty good but not quite perfect, just want to reset anything the previous owner might have messed with.
Thanks
Thanks
