skeeter beeter
- Jan 11, 2008
- 8
can i use a vro pump from a '92 90hp on my '86 200hp without running lean. reason i'm asking is because someone took off the original vro, and put one standard fuel pump on. runs like crap. i know running standard lift type fuel pump,a 200hp needs two pumps. just wondering if the 90hp vro will work only to check to see if this is the problem before i spend $400 on a new vro pump. i pre mix, so the oil pump part i don't care about. just don't want to run lean during testing.(low fuel flow rate.)
thanks for your help
mike
mike
