Ficht Fuel Pump
danmah
I have 1999 Ficht 150 and my fuel pump has started to slip up and leak gas. I have pushed it down and re-tightened clamp but it slides up again and exposes two o-rings. I have since fastened down with tie straps temporarily. Does anyone know what is causing it to slip up even when the clamp is tight?
boobie
Re: Ficht Fuel Pump
I think you need a clearer explanation of what is happing here. Slides up ??? Which fuel pump, high or lower presure?
danmah
Re: Ficht Fuel Pump
Seaman, It is the one in the very back of engine which has the shaft with 2 o-rings on it. Dont know if high or low pressure.
boobie
Re: Ficht Fuel Pump
Any way to post a picture of this ? Remember the saying of 1000 words.
