wagemaker1
- Jul 29, 2008
- 10
Hello all,
I have a 63' Evinrude Speedifour that is giving me fits. When I run it in the tank, with the cowling off, there is a tremendous amount of exhaust coming up from around the powerhead (down inside the lower cowling). If the wind is blowing right, you can see the exhaust being sucked into the carbs. and the motor begins to bog down. Then when I put the cowling on, it pretty much stalls out. What could this be? I pretty much ripped apart this engine last summer, and thought I checked everything, guess not.......
Also inside the outer housing, mid shaft, there is a foam (or neoprene) gasket. It is pretty beat up and torn. Was this to prevent water from going up into the engine, or for exhaust?
Any help or insight is greatly appreciated!
