Re: 1955 Evinrude 15 hp shifter problem
Hi and welcome to the forum! By kicking out of gear, do you mean it thumps liek you're hitting a log? If so, the motor probably has a worn clutch dog/forward gear in the lower unit. It could also be play in the shift linkage. Remove the oval cover on the side of the leg and check the coupler where the upper and lower shift rods connect. Are the bolts in place and tight? Check for any play by holding the shift lever in forward gear and using a long-nosed pliers on the shift rod to check for play.
