Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1975 25hp johnson outboard
  • 1975 25hp johnson outboard
    I recently bought a boat that has a 1975 25hp johnson outboard motor. Put in the water, cranked right up. Tried to go full throttle and it sounded like it skiped a gear and went back to mid throttle and it did this everytime I tried to go full throttle. I took apart the lower unit today just to check out everything and everything seem to be fine besides the oil in the lower unit was carmel color. Im not very experienced with boat motors or have ever done anything to a boat motor. Any advice please try to break it down where Ill understand. also should I clean the carb? I took the top spark plug out and it seemed dry. Thanks!!
    Re: 1975 25hp johnson outboard
    Sound's more like an ignition problem where the engine is dropping spark to one cylinder.
    • #3
      start with a compression test.
      then test spark
      Baba-buoy.
