Frank Culler
- Jun 14, 2010
- 4
I have a 1988 9.9 evinrude that will not shift into reverse. It will shift into foward and neutral fine. It will shift into reverse if I push back on the stater where the plastic piece on the shift rod touches it. It seems that the stater is not going back far enough when I put the throttle in the shift position. Is there an adjustment any where for this. I do not know alot about these motors so any help will be wonderful.
