Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1979 85 hp evinrude gas to oil ratio?
  • 1979 85 hp evinrude gas to oil ratio?
    What is the gas to oil ratio for a 1979 85 hp evinrude outbard boat motor?
    Re: 1979 85 hp evinrude gas to oil ratio?
    50/1 tcw-3
    • #3
      Thank you. The person I got the boat from said 40 to 1. I am a little virgin to boating. What is tcw-3?
      • #4
        TCW3 is the current spec for a two stroke outboard engine oil. TC = two cycle W= water cooled. 3 is the current spec, the previous one was 2.
        Would not hurt to run 40:1 but not necessary
        50:1 is near enough 1 pint in 6 gallons
        20ml per litre if you are where litres are used. (The rest of the world outside the USA)
        • #5
          Thank you. I will get a manual.
