The motor cranks easy and idles good but when I get on the throttle it bogs and I have to prime the bulb. Then I get back on the throttle and it runs fine sometimes and other times I have to prime the bulb again( maybe 2-3) times. After I go through this process I can run for hours without any problems until I stop for an extended period of time and then I'm back to where I started. It's losing fuel pressure in the line; the bulb won't be close to being hard. Can someone please help? The local shop tells me the vro needs to be replaced, but I'm not so sure about that since the motor runs good except after sitting
