trobinson017
- Sep 12, 2004
- 183
I noticed a couple of head bolts rusting on my Johnson 130 motor. I've attached a couple pics. These are on the same side (port), one on the top cylinder, two on the bottom. No other bolts are rusting at all. Can I simply try to remove the rusted bolts and replace them or would I need to remove all, replace a gasket and replace bolts? What if the bolt heads round off or are so rusted a socket won't grip? What options would I have? Is this something I can attempt myself or should I call a mechanic? I have one that does house calls.
TIA!
TIA!
