I found out why my 74' 135 rude wont spin a 19p prop. I have 125lbs of compression on all four cylinders. With a spark gap tester on all four plugs, it runs and jumps spark on all four. After running, all plugs have a little bit of fuel on them. The fun part is that when its running on the muffs and you ground the plug leads one at a time, it makes almost no noticeable difference on any cylinder except #3. On that one the engine dies. Infact, pulling any two plug leads allows the engine to keep running so long as #3 isnt one of them. What could possibly cause this?
I used my timing light to make sure the carbs were all spraying fuel, they are.
