AguaSki
- Jul 4, 2005
- 545
What does the tension knob adjust? I ask because my warm-up lever has become really sloppy. I have about an inch of play before the warm-up lever has any effect. Will the tension knob adjust the warm-up lever issue or just the main throttle cable going into the control box? I have a manual that contains a parts diagram, but I can't tell how the tension knob works. I was thinking about tearing the entire control box open this weekend to see if there is something I can adjust from the inside to get rid of the slop in the warm-up lever.
The motor is a 1978 Johnson 140 hp with original controls.
