Re: 60hp Johnson
If the motor cools down for a hour or 2 it will start up on it own not unplugging the cannon plug and jumping the sylinoid
What if its warm???
Still sounds like a problem in the control box,maybe the kill wire is crushed or somehow getting grounded? are you sure all connections at the switch are tite and not touching eachother or ground,try disconnecting the kill circut at the powerpack,its the black with wh stripe.it will allow to run but wont shut off.If it allows good running ,you somehow getting ground to the kill.Make sure the cannonplug has no corrosion,corrosion carries voltage ,as minimal it is ,it will screw ya up.
