I have a 1964 speedtwin that I got for free. I rebuild the carb and fuel pump and I idled nice in a tank. I want to chance the impeller but I can't get the screw that holds the shift linkage inside the lower unit. The shift rod is rotated so the screw head is pointing the rear of the unit and I can't get a screw driver in it. I have tried shifting and, as expected, it only moves the rod up and down. I have had the gear case apart to clean and couldn't get the shift rod to rotate with that off either. Not sure what else to try.
I have just started tinkering with these old motors but I am trying to figure it out as I go.
