I inherited what I think is a 1969 Evinrude 6 horse outboard. When I got it the motor wouldn't run, so I took it to the local outdoors shop (which has since closed) and they charged me $35 and it ran like a top when I got it back. I last ran it in late Feb when I picked it up from the duck club, and last weekend couldn't get it to start. I HAVE seen the FAQ on motors not starting, but have a couple of questions
Is there an OEM manual available for this motor and if so, where? If there is no FSM available, are the generic manuals offered here sufficient?
When I pump the bulb, gas flows out of a hole on the front of the carb. Is that hole supposed to be open or ?. The plugs do not appear to be getting wet, so doesn't look like gas is getting to the cylinders. Stuck float possibly? Anyone have a link to a carb rebuild post with pics on a similar carb? I've rebuild some Jeep carbs, but never tried small engine carbs.
After running the engine for a few min, it seems to get slower. From what I've read here that would probably be coils going bad. I'm sure these are probably the original coils. Is there any way to test them or does one just replace?
Anyone have a link with pics showing water pump impeller replacement? Mine spits water out of the back, but not a great stream, and for peace of mind I feel like I outta replace it.
Lastly, while I'm fooling with this thing, I know I'm not supposed to run it out of the water, so where is the water pump intake? There are a few small holes on one side of the foot right above the prop. Is that the intake? I know I need to submerge the water intake to keep from ruining the impeller.
Thanks for any input anyone might have.
