I have a '77 evinrude 85. Seems to run well at higher power settings, but is a little rough at idle, sometimes makinmg it difficult to get into gear without stalling. It seems to do better cold than hot.
I recently changed the plugs, which seemed to help a little.
I have white smoke at idle, comming from the two holes on the rear of the engine, just below the lower cowl. I assume these arer the tell tale holes, as they are hooket to two rubber hoses coming off of the heads. A spatter of water comes out of these holes at idle. No smoke that i can see at WOT.
I inspected the impeller, and it is in new looking condition.
I thought maybe white smoke meant I was running rich, but I recently read here that it is potentialy steam from a blow head gasket.
Is a head gasket job a cheap and easy task? Is it still possible i'm running rich at idle?
I haven't checked compression yet, but will as soon as I can get a compression gauge.
