When I run wide open for 6 or 7 minutes it starts cutting out like its running out of fuel. When I slow down to about 2000 rpm it runs fine. Then when I open it up again it starts cutting out. Anyone have this happen?
Also, the starter bracket bolt above the solenoid was loose(stripped out) and actually bounced on the pos terminal of the solenoid while running that also goes to the rectifier and the starter button. Can the rectifier get shorted out?
