i need to know point setting for 1975 25 hp johnson ? not getting fire to plugs
E elrico Recruit Joined May 18, 2010 Messages 4 May 31, 2010 #1 i need to know point setting for 1975 25 hp johnson ? not getting fire to plugs Last edited: May 31, 2010
B BigB9000 Lieutenant Junior Grade Joined Dec 5, 2007 Messages 1,154 May 31, 2010 #2 Re: points settings 25 hp johnson Should say on top of the flywheel.
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,195 May 31, 2010 #3 Re: points settings 25 hp johnson .020"
E elrico Recruit Joined May 18, 2010 Messages 4 Jun 1, 2010 #4 Re: points settings 25 hp johnson thanks for info they were set to low ,iam still not getting fire to plugs ?
R raczekp1 Lieutenant Joined Mar 30, 2010 Messages 1,327 Jun 1, 2010 #5 Re: points settings 25 hp johnson hi maybe it's time to chnge coils and condensers and cables or maybe the problem is witch plugs cap-there is no conection
