linkage
swyne
Hello folks,I'm looking for the linkage rod (1) that runs from the throttle control arm which pivots to the I guess its the stator plate? under the flywheel. I have a 1987 88hp SPL The model number of the engine is J88MSLCUS.
http://forums.iboats.com/showthread.php?t=382673 scroll down you'll see it!
Thanks in advance!!
jtexas
Re: linkage
part number 0033091, spark advance rod. ishopmarine dot com has it.
swyne
Re: linkage
Thanks for the info, however ishopmarine does not recognize this part number. Tried Google and no help!
