I have a 1976 johnson 50. my problem is, two cylinders each has a carb, and butterfly. there is a linkage that is attatched to both carbs. The adjustment screw stripped out and i can't get both carbs to run in unisen any longer. It still runs but just up to half throttle. then it boggs down. what is the trick for adjusting the carbs to be identical. thanks.
