Re: 2002 johnson no full speed
also you really have not ruled out fuel yet, try a new fuel line with new connectors, this has been a very common problem. once I even had to replace the male fitting on the tank. try pumping bulb while it is messing up and see if that helps, if it does, its fuel problem if it does not, its probably spark related.
