Hi guys, need a bit more help with my starter. Let me first tell you all what happens when I try to turn her over, the little gear that rises to turn the big wheel on top (thinking that is the flywheel, but not sure) just spins it won't rise up and engage the big wheel. I proceeded to tap the side of the starter a few times and voila!! she started right up. Is the rod that holds the small gear and goes into the starter called the bendix? If so can I use 2 in 1 oil to stop her from sticking?
