Re: johnson 115 v4 engine with special shaft
If it were a factory perfomance engine, It would be hard to say what is different. At the Johnson factory service shool They have engine's on display in the hallway out side the clss rooms. They go from the rotorary Wankel, to the V-8. On the piston engine's, the cylinder block is sand cast. They have a two throat carb on every cylinder. The only wiring is to start the engine, and shut it off. There is no neutral, or reverse. The only linkage is to the 3, 4, 6, or 8 carb's. They don't look like any engine you would see at a dealership. The V-8 with it's competition gearcase look's like it could take you for quite a boat ride. Show us some pictures with the hood off.
