MakO17 90 EvinrudE
- May 9, 2010
- 28
hey everyone i hav a 1996 evinrude v4 60 degree loop charged 90 hp. i recently clened out all carbs and went to run the boat today. i started it up one try and it sat for about 5 mins in neutral just idling perfect. i gave it a bit of gas while in neutral to let some gas run through the motor at about 1200 rpms. after 2 minutes of this i came down back to neutral and the engine shut off. i tried to start it again and no luck. i tried several times and it started once for about 3 seconds and then shut off. when i turn the key i here the starter engage and turn the flywheel it sounds like its gonna start and then just dies with a weird noise like a screatch. (eeeeaiiirrr). thast the noise it makes. if anyone has any ideas please let me know. thank you
