Need to remove the starter to get to the nut holding the carb on in orderto remove it for rebuild. The manual shows removing the pinion gear on top of the starter but not specific on how to loosen the retaining nut. Anyone have a tip on how to remove that nut without damaging the gear by holding it from turning?
Also - is that Evinrude 28 Spl a good engine and just what does the "special" designation mean?
