Bluffdweller
- May 12, 2010
- 1
I am attempting to remove a 175 HP 1990 Evinrude V6 powerhead.The model number is E175TXESE. I have the lower unit off and have removed a total of 6 bolts from the sides of the powerhead. Two from each side on the forward part of the powerhead and one from each side towards the rear of the powerhead. I have also removed the three nuts from the studs located towards the rear of the powerhead. The "SELOC" manual (I know I should have bought Evinrude's Service Manual) states that these are all of the bolts/nuts that need to be removed. I have the lower cowl cover removed and see several bolts that looks like they could be attached through the exhaust housing. I have tried to free up the powerhead but can not get it to budge. I disconnected the shift linkage when I removed the lower unit. Could there be any other bolts holding the powerhead in position that the manual has neglected to mention? I really need to get this powerhead off in order to ship it out when rebuilt unit arrives. Any help/ideas will be appreciated.
